7: The FF-1216 and F-00214 were located. 8: The FF-1216 and F-00214 were cut leaving a in. overlap. 9: The FF-1216 and F-00214 were connected to the FLF-00023.
08/21/20 2 Hrs
1. PENDING. ES-7244 Jack screw is missing. 2: The 3 ES-421-0108 were connected to ES SW K1-AABAAAAA 3:The connector lebeled PDF was connected to the GDU 460 4: The phone jack connector lebeled ELT was connected to E04.5. 5: The excess wire was gathered and secured with tie wraps.
11/24/20 0.5Hrs
The connector labeled IGNITION from the Harness was to the AV-60007 Ignition Module
