GA Aerospace’s Web Site
Date:  3-23-2021
Number of Hours:  7.70
Brief Description:  36iS/U-03
19/03/2021 4.5 hours.
Worked on the left side.
1. The U-00001A, U-00001B and two U-00002s were clecoed #30.
2. Material was removed up to the scribe line from the U-00001A and the halves match smoothly.
3. U-00001A and B are aligned and temporaly placed a tape across thwe seam.
4. The bracked hole was transfered to the inside of the U-00001B.
5. A pilot hole was drilled centered of the tire inflation marked.
6. The wheel fairings were match-drilled #40 at each dimples starting from top-center. Each drilled hole was clecoed,
23/03/2021 3.2 hours
Worked on the right side.
