GA Aerospace’s Web Site
Date:  10-30-2018
Number of Hours:  13.76
Brief Description:  29iS/U-04
10/29/18: 1.16Hrs
3. F-12116 L&R were match-drilled #40 using F-1201P L&R, they were then deburred.
5. F-1202N and F-1295 were separated.
10/30/18: 12.6Hrs
1. The upper surface of the bottom flange of F-01201A was smeared sealant.
2. The upper firewall assembly was riveted to the fuselage.
4. F-12116 L&R were riveted to F-1201P L&R and to the side skins, the rivet that goes into the nutplate on F-1201P L&R was also riveted in this step.
6. The underside of F-01201B was smeared with sealant.
7. F-1202N L&R was riveted to the side skins.
8. F-1295 L&R were riveted to the side skins and to F-01201B
9,10. The firewall was sealed using tank sealant and was tested using a flashlight.
Underside of F-01201B
