GA Aerospace’s Web Site
Date: 9-21-2018
Number of Hours: 16.53
Brief Description: 21iS/U-06
9/20/18: 1.33 Hrs 1. F-01299 were separated. 2. F-1216 were separated.
9/21/18: 15.2Hrs 3. F-00122 were separated. 4. F-00123AB were separated. 5. F-01215 L&R were deburred and labeled. 6. A total of eight F-01215 L&R got material removed that was in the middle of the lightening hole. 7,8 . Two F-01299-L were clecoed to rib #4 and #8, two F-01299-R were lcecoed to ribs #1 and #5, no filing was required. 9. Three holes were countersunk #40 on two F-00123A, these were riveted to F-00122 and then one to rib #1 and another one to rib #5. Same thing as the previous step but using F-00123B instead of A, and these were riveted to ribs #4 and #8. 10. Eight holes were final-drilled #30 on F-1216L, F-01299-L&R and riveted to rib #5, this was repeated in rib #1, F-12102A-L and F-12102B were also riveted to rib #1. (This was completed on September 24th, as we needed clearance for an expanded hole) 11. Eight holes were final-drilled #30 on F-1216L, F-01299-L&R and riveted to rib #4, this was repeated in rib #8, F-12102A-R and F-12102B were also riveted to rib #8.
