GA Aerospace’s Web Site
Date:  3-19-2019
Number of Hours:  2.10
Brief Description:  *** 11iS/U-09 pending final assembly.
1. 12V were temporally connected to the black wire, white wire V- to extend the servo shaft, then the battery was disconnected.
2. 12V were temporally connected to he white wire, black wire V- to retract the servo shaft, then the battery was disconnected.
3. All openings on the wire insertion were sealed.
4.The connector on the end of the WH-P30-1 was plugged into the connector on the wires from the ES-MSTS-B6-7T-165.
