03/11/19: 2.4Hrs 1: The Rod end bearing and Jam nut was installed into the F-1287F achieving a dimension of 16 11/16 in and the bearing body was aligned with the centerline of the pushrod assembly.
2: The jam nut AN315-3R was installed onto the trim servo, then the clevis rod to the nut, the rod unscrewed one turn then the nut back to the rod.
3/19/2019 1.8Hrs
3 & 4.The F-1287A-1 servo tray was installed to the F-1211D attach brackets with the indicated hardware. the cotter pin was fully installed when the tailcone attached to the fuselage. 5. The rod end bearing was temporaly installed.
