03/15/19: 3Hrs 1, Wires of the ES MSTS-B6-7T-165 were strung through the indicated snap bushing.
2. The pitch trim servo was installed to the F-1287A0-1 servo tray.
3. The ES SA-1017 Socket pins were crimped onto the ends of the wires coming out of the ES MSTS-B6-7T-165.
4. Both L&R F-1287D clevis plates were attaches together using the indicated parts and hardware.
5. Both L & R F-1287D clevis plates were match drilled
03/19/20: 2Hrs Step 6: The F-1287F threraded insertt was clamped into the curved end of the F-1287E pushrod. A rivet was used to align the holes in the threaded insert.
7. The holes of the F-1287E pushrod and the F-1287E Threaded insert.
8. Both L&R F-1287D clevis plates were riveted to the F-1287E pushrod using the indicated hardware. The F-1287F threaded insert was riveted to the pushrod using the indicated rivets.
