02/24/20: 1.37Hrs 1: CS-G405 foam, was placed over the spacer on the control sticks. Worked on 2.
02/25/20: 2.9Hrs 2: Safety wire was used to route the control head wire through the control stick. 3: The control head was riveted to the control stick and spacer. 4: A snap bushing was installed on both control stick tubes, also heat shrink was installed on the wires and they were tie-wrapped to the tube. 5: The control head wires were crimped and inserted into a D-Sub 9 Pin connector. 6: Two backshells were trimmed as instructed and the D-sub connector was installed into it. 7: Sticker labels were installed onto the control heads.
