02/24/20: 0.55Hrs 1. F-01244 L&R were dimpled #40 and nutplates were riveted to them. 2. The F-01244-L, F-01245-L and F-01244-R were installed with the indicated hardware. 3. The nutplates rivet holes in the F-12101 were dimpled #40. The nutplates were dimpled then riveted to the F-12101 with the rivets indicated. 4. The sides of the F-12101 were riveted together with the rivets indicated. 5. The F-01293 were sanded and painted before installation. 6. The F-01293 was installed with the correct hardware. 7. The F-12101 was installed using the correct hardware.
