1. Two (one for each seat) pins of a lenght of 14 1/2" were cut, then they were bent 90 degrees at 1" and given a dull point. 2. The seatback brace was attached to the seatback assembly using the pins. 3. The pin was secured using a safety wire.
09/08/20 0.25Hrs The pin was secured again using a safety wire, after painting.
