Brief Description: PAP Tests FLIGHT CONTROLS CHECK Pt. 2
Pushing the stick left moved left flaperon TE up and right flaperon TE down. Flaperon skins are flat between the spar and trailing edge. Flap position indicator was calibrated. Smooth operation of flaps was confirmed. FLAPS TESTS Stabilator cable turnbuckles have safety pins. The tension of both stabilator is adjusted between 35 to 45 lbs and pulsing them does not cause a slap.
