GA Aerospace’s Web Site
Date:  5-13-2019
Number of Hours:  13.00
Brief Description:  39iS/U-16, 39iS/U-17, 42MiS/U-11 42MiS/U-12
42MiS/U-11:
The main parts of the harness were routed.
42MiS/U-12:
The fuse panel was attached as instructed in step 1. Two AN365-632A nuts had to be installed in th 2 bottom holes.
The WH-P30-1 was already crimped, so the cables were installed into the ES-00140 and the housing was attached. The AP module pins may be switched later after the tests according to Van's since both cables were white.
Step 5 and 6 was completed, a total of 2/8" were trimmed from the shaft of ES-00195 to make the dimmer closer to the panel.
The fairing was once again sanded and filled with bubbles.
