Today we start by reuniting all pieces we will e using in Section 6, the first part of the empennage that consist on the Vertical Stabilizer. Once we had all parts, we continued reading the first page and proceed to do the primal steps. We do two pieces of the “Hinge” by cutting where the marks indicate. We used the saw band to separate and the sander to finish and deburr. Tip. Use the sheet scissors or the saw band to cut but not exactly on the action line, use the sander to do a more accurate finish to the work.
