Brief Description: conecting pins for the tipup, jettson
I made these parts for the canopy connection, in the end I may just use bolts, however, for now I'm following the plans, I don't believe I would ever pull the jettson in flight to get the canopy off. However, I will be removing for working on the project prior to finishing it totally and this would be a good way to get into that area if I have the need.. Some builders just install bolts to hold the canopy and others use this type of attachment. I will not put the hat handle all the way through my panel, I will just make it accessable for serve work.
