Brief Description: fitting and drilling subpanel seal, forward top sk
I have been back at fitting and drilling the sub panel seal to the sub panel and fitting forward top skin to ribs and fuselage. This has been a long process many hours of work on the right side of the skin. This side was about 1/8" high in the area of the #30 cleco's. After many hours I used a tiedown to pull the skin down into place, as the skin came down the cleco's would pull it in and now it seems to fit very well. In the beginning there were a lot of questions and emails to other builders to see what they had done to get this skin to fit.
I then drilled the forward top skin to the firewall and the other ribs. I worked a while fitting the rib that was removed and relocated directly behind inst. panel. I need to get this all located right prior to moving on to the next step of construction. Then a few hours working on the fuse block bracket that I will locate directly back of the panel right side.
