Jim's Web Site
Date: 2-6-2008
Number of Hours: 10.00
Brief Description: Wings and foward fuselage
Over the last few days I have worked on the fuse block and tray, also, worked on final drilling of flex line for the wing wiring. I moved the fuse tray to the left to accomadate the outside air vent, I will need to move the right rib to the left 2 inches making the panel is more user friendly. I think this will all work fine.
I drilled four holes in the subpanel for wiring the main buss and the Ebus, I received the fuse blocks from B & C Specialty out of Newton, KS., their website is www.bandcspecialty.com
I also, ordered a few tools from them over the last few weeks. They get their orders out fast. I'm sure they will be a big part of the wiring process.
If you are thinking of making a fuse tray be sure to remember the outside air vent needs about 2.25 inches on the right side of the tray, consequently, do it right the first time. I also put a doubler on the subpanel wall. You will also need to move the right rib about 2 inches to the left, so that the tray can lock in place to the panel. Just a heads up!
Fuse buss tray
tray - moved left the rib will be moved 2 inches.
more tray work on bench
