Seven Whiskey Fox
RV-7
HS work. Clecoed HS up
Cut, fluted and edge treated all ribs in HS.Final bend in front spar reinforcers to 6 degreesClecoed up the HS. Match drilled all rib attach points to #30.Drilled HS-404 and 405 ribs rivet holes at front spar attach point.
RV-7 Home
