Brief Description: finished most of HS , added 601PP skin
Took apart structure and deburred, reclecoedClecoed on HS-601pp skinsEnlarged the 708 to 603pp holes to #19Mark hole locations of 601pp on hs-404 and 405 ribsFluted 404 and 405 ribs and marked center linesdrilled and clecoed 405 to 603drilled the skin 601PP holes to HS-405 to #40Drilled hs-702 to hs-601PP outboard to inboard. did both sides and top and bottomclecoed HS710 and hs-714 to hs-702ordered angle drill bits, more 3/32" clecoes and flush set from Cleveland. Another $84.00This looks like a real airfoil!!!!!!
