Brief Description: Workshop, Finish rear spar, most of front spar, fi
touch up on primer of rear sparHung shop light above main table, works great.Added 2' X 6' X 3/4" of particle board on top of half the table for drilling and clecoing.clecoed whole rear spar and added VS164 bearing, match drilled its mounts, primed VS 164, and riveted the entire HS-411 bearing structure up. Clecoed that to the rear spar assembly.Enlarged the 4 bolt holes for HS-411 to #19.Rear spar done and ready for final riveting later.Front spar flanges trimmed and hand radiused to 1/4" and dressed on scotchbrite wheelFront spar reinforcers bent to 6 degrees. Front spar flanges bent to 6 degrees. dimpled and counter sunk the four center rivet holes for AN426-4 rivets. machine counersunk the reinforcers underneath the spar flanges.
