Freds Web Site
Pulsar XP
Fuselage CM P-xx
Inspected and sanded the aft bulkhead.
Started at 8:30pm and Stopped at 11:30pm
Bonded two 1/2 by 1 1/2 inch 3 oz. glass on the front side of the aft bulkhead over the end of the trim spring attach pin.
Inspected and sanded the vertical stabilizer.
Bonded a 2 inch block of foam above the top hinge on the verticle stabilizer and filled a small hole on the bottom of the vertical stabilizer.
Strted the sanding of a 3/4 inch deep channel on the back of the Verticle stabilizer.
Pulsar XP Home
284
62
Inventory and Inspec
Vertical Stabilizer
