Brief Description: Radio install - complete for flight test
I didn't test it with the engine running yet. But - soldered the two warning light's leads (4 wires) behind the center panel, connected the + side to the fuse panel, and soldered up the PTT lead for the pilot's side. Put the new BNC connection on the antenna lead. Tested the intercom function and the reception. Seems ok so far. All that took far longer than what it looks like from the description. Anyway, still need to pull the seat and make the "final" PTT connections to both sticks, and also want to add a BNC elbow at the radio to route the antenna lead better, but this will get it in the air again. Also will spend some time programming some of the memory - it has 100 memory channels, but to get to some, you've done more button pushes than just tuning directly.
Panel reassembled. Wires on the right below panel aren't done yet.
