Removed the masking from the inside. If I had another tube of Sika adhesive, I might go over the aft side of the aft bow. Can't do the forwards side of the forwards bow because it would get into the trim strip that it rests on. But I can't see the aft side of the aft bow when it's closed, so I'll call it good for now. The latch needs some work - to shave the edge of the canopy that ended up resting against the latch angle. And also to sand the forward and aft outer edges of the canopy itself because these have a little recast on them. But otherwise, it looks really nice.
