Worked on adding the details to the F09-02 seat belt attach assembly, with modifications for the lowered seat. In one place (see close up photo) the rivet heads for the idler support clips interferes with the seat belt mount bracket, so I filed small reliefs on the bracket to get it to sit flat. Also had to improvise some additional rivet holes on the upper 1x1x.125 angle stock part - when relocating items to the center, there are some "blanks" on that angle. No particular spacing is called out on the lowered seat mod instructions, so I went with the usual more or less 1" spacing.
Details mounted to the seat belt attach assembly.
Location where rivet heads interfere.
Added a few more holes to this upper angle to fill in the blanks.
