Completed fabrication on LHS fuse side panel by: redrilling new motor mount bracket 3/16 bolt holes, finished the phenolic parts for the canopy latched (countersunk bolts & installed), riveted the upper angle to the side panel (I had left it unriveted to install the phenolic parts), noticed that I STILL left off the upper and lower firewall attach clips (these bolt onto the motor mount bolts).
