Located and drilled the hole in the RH panel for the upper end of the fuel sight gauge tube. Made an extension of the right side of the panel for the lower end of the fuel sight gauge. Some have commented that they can't see the bottom few gallons in the tank. I would think these would be the most important, but I don't want it so low that the gauge itself becomes a trap. Cut hole pattern for a 2 1/4" gauge in the RH panel as well. This won't be used initially, but it could be a spot for an g-meter.
Right panel with upper and lower holes for the sight gauge.
