Shortened the control sticks by 1" to improve the clearance to the bottom edge of the panel. The PTT's in the grips add about 1/2" of that back. Also drilled a hole at the base of each stick for the PTT wires.
Stick 1" shorter. Panel is 2" lower than stock. Clearance is about 2".
