Finished off the pushrod cover. Drilled the attach angles to the in-place structure. Deburred, riveted. Installed the bolts holding the cover in place. Only thing is the forwards bolts are at about the level of the pushrod - very difficult to ever remove again. Probably will take the cover out one more time and put nutplates inside the cover at the forwards bolt locations. The aft ones are below the pushrod - much easier to get at.
