Installed the trim cable. Installed the grommets in the fuselage frames, the clamps on the elevator, cut the cable housing to length and installed the forwards clamp. Made the Z bend at the aft end and attached it to the trim tab. Can't cut the front end and finish it off because I don't have the AZUSA cable swivel. These weren't in the Wick's hardware kit for the brake cable either, and I didn't realize at the time of ordering the brake parts that the airplane needs 3 of these, not 2.
From previous entry - touch up paint on the weldment.
Aft end of cable. Not easy to get to the forwards clamp retention screw.
Forwards end of cable. No cable swivel, so it's not attached.
