Bent the T12-07 forward spar fitting in the modified bender. Worked out well. The bend radius is correct at 0.5" due to being bent over a 1" dowel. The bend is slightly further down/forward on the part than what is called for in the print. (6/1 note - when assembled into the vertical tail, this bend location places the mounting flange about 3/16" forward of where it should be. May drive the need for a spacer between it and the mating flange on the horizontal stabilizer, or it may pull in.)
