Spent about 1 hour working with the table saw. Part needed was a strip of MDF to make a bender box wide enough for the T12-07 forward spar fitting (the bender as I had it was too narrow). While I had the table saw out, I ripped out the strips for the fuel tank supports out of .060, and cut the .090 and .125 wing spar doublers to width. That should do it for the table saw. It makes a huge mess. Made the bender box. Drilled the skin to the vertical tail frame, 2nd side. Got good edge distance on the spars and ribs except for the lowest one. Decided to mount it below its attach angles instead of above to shift it down a little. Added a .032 spacer under the forward angle to shift it down evenly. Had enough .025 channel stock to make another lowest rib. Got the good edge distance on it.
