EJ Andersons RV-8 Builders Log
Date:  5-25-2012
Number of Hours:  3.20
Manual Reference:  Section 6
Brief Description:  Riveting the Vert Stab Substructure
I Clecoed all rear spar parts together (VS-803, VS-808, VS-410, VS-411, VS-412) and taped over the holes reserved for the rib attachment. All of these parts were then riveted together.
Clecoed and riveted the front spar and ribs together (VS-704, VS-705, VS-706, VS-707).
Then Clecoed the skin (VS-801PP/VS-901) to the forward spar/rib assembly.
You can see where I ran out of the old primer and began using the new. I didn't feel it necessary to strip the old since it will be inside the stab and not visible.
Rear Spar riveted together
Forward Spar and Ribs riveted together
Vert Stab skin clecoed in place
