Brief Description: made aft rudder cable clamps and routed port cable
shaped and slotted aluminum angle as rudder cable aft clamp bracket. The plans called for 3/16" slot, but measurement of the cable indicated slot must be 1/4". After cutting the slots and verifying fit with cable I shaped .032 strips as hold down for cable as part of bracket. The hold down strap utilizes the thru hull mounting screws as shown in Pic 1
