Brief Description: Backdrilled and bolted F-5 and riveted
Pulled lower longeron bolts at foot and set F-5 between foot and spar. Backdrilled from spar thru F-5. Located and drilled F-5 thru upper longeron. Countersank and de-burred rivet hole. Reassembled foot to spar with F-5 trapped and then flush riveted at upper longeron
