Brief Description: began clamping and assembling firewall to longeron
Set firewall at proper height and clamped lower longerons in place. Clamped pre-shaped upper longerons and squared everything using equal distance cross bracing. Made first cut for vertical angles, but upper longerons were not sitting properly, vertical angles are too long. Re-cut and re-drill tomorrow after adding 1/4" bracing on lower longeron.
