Brief Description: revised and attached lower longerons
Attempted to mount lower longerons to center spar, but bolt pattern on spar too close to 23" to use existing feet. Recut feet to overlap end of longeron and trimmed longeron to allow overlap of feet. Positioned longerons, backdrilled and mounted. Need longer AN3-12A bolts. Spacing was so tight I had to grind head of one bolt. After I get replacement longer bolts, I will add one additional bolt to the port lower longeron foot.
