Brief Description: Fit F-10 bearings and mounted yoke
Disassembled F-10 bearings and removed stop to make bearings free centering. Assembled purchased yoke and mounted with bearings in the center wing. Cut cockpit elevator push rod and fit end fitting and MM-4 bearing to end. Drilled, cut and shaped opposite end to accept MM-4 female end. Added end fitting and riveted it in place on long elevator push rod. Drilled and riveted previously shaped 3/4" x 1/8" angle to firewall sides.
