added fwd floor supports. Layed out hole pattern on cenr bottom skin. Drilled rivet holes in support for vertical angles and F-5. clamped supports in place and match drilled thrul skin into supports. Match drilled thru supports into vertical angles and F-5. Dimpled bottom of supports and lower skin and riveted all in place.
