Brief Description: trimmed bellcrank support to eliminate interferenc
Trimmed bellcranks suport to allow free travel of control rod. Align left supports with control rod before attachment on left wing. Made 20 degree and 15 degree gauges to align ailerons when setting up final rigging. Checked aileron travel and zero reference with gauges and adjusted for preliminary fit up. Looks good. Cut stick to bellcrank control rods, reamed to 7/32" and then tapped four ends nto 1/4 - 28. Threaded mush easier this time. Chased MM-4 fittings and installed same into the control rods. Now just waiting to build the fuselage so I can connect it all.
