Brief Description: riveted aileron hinges in place
After refabricating hinge blanks I re-located aileron on wing and riveted hinges in place. Riveted bellcrank supports to right wing in holes previously drilled. Rear wing spar reinforcement needs to be trimmed to allow full 15 degree down deflection. Upper bellcrank support needs to be trimmed to allow control rod free movement to 15 degrees down deflection.
