Brief Description: 3 - primed tip rib brackets and test fit ribs
I scuffed and primed the tip rib brackets and test fit the ribs.
I clecod every other hole in both tip ribs, but the ribs are too wide at the rear spar. I'm not sure I can fix this as it appears to be formed at the wrong dimension, and I wouldn't know which flanges (top or bottom) to re-bend.
I have an email into TAF for advice or replacements.
