DOUGs Web Site
Date:  2-26-2019
Number of Hours:  0.80
Brief Description:  1 - Shortened left steering pushrod
The left push rod needs to be about 7mm shorter in order to have the same amount of adjustment of the right. It would bottom out when I adjusted the nose gear to align with the center of the airplane / rudder.
I drilled out the cap rivets, measured and cut off 7mm from the left push push rod, labeled and re-assembled the pushrod. Finally, I reinstalled and adjusted the steering. Looks reall good now.
marked and cut off 7mm
assembled and labeled left push rod
re-installed and adjusted steering push rods
