Brief Description: Cabin heat, oil tank bracket and fuel pump shroud
I finished riveting the cabin heat control box together and to the firewall. I then riveted the engine oil tank mounting bracket to the firewall. Finally I cut slots in the electric fuel pump heat shroud around the fittings so that it can be removed without removing the fittings if need be.
