DOUGs Web Site
Sling 2
Rudder / Vert Stab connector for tail light
I added a connector to the 4 conductor wire for the tail light that routes through the hinge of the rudder so that If I ever need to remove the rudder I can disconnect the wiring.
soldering connections
heat shrinked and labeled
ready for rudder assembly
Sling 2 Home
705
109
Central Fuselage
86
138
Elevator
Horiz Stabilizer
Rear Fuselage
63
101
Shop & Tools
Undercarriage
Vertical Stabilizer
172
