Brief Description: 2 - Transponder and ADS-B "IN" antennas
I drilled a mounting hole and installed the transponder antenna through the double-skinned floor through the access hole provided in the interior skin. I created a new access hole at the firewall, and drilled a mounting hole for the ADS-B "IN" antenna and installed it as well.
The marker beacon, transponder and ads-b in antennas are all about 26" apart.
duct taped antennas while installing mounting hardware
