DOUGs Web Site
Sling 2
1 - Marker Beacon antenna installation
I fabricated a backing plate for the marker beacon antenna, located and match drilled the template to the lower fuselage skin just behind the landing gear and then installed the MB antenna with the hardware provided.
Marker beacon antenna and template
backing plate fabricated and installed
MB antenna installed
Sling 2 Home
705
109
Central Fuselage
86
138
Elevator
Horiz Stabilizer
Rear Fuselage
63
101
Shop & Tools
Undercarriage
Vertical Stabilizer
172
