Brief Description: 1 - Installing Port position light
I powered up both position lights to make sure they worked before I installed them. Looks good and bright. Strobes are really bright.
I installed the rivnut plate with similar issues from the starboard tip. I ended up countersinking the holes on both wing tips to reduce the overall thickness which helped. I completed the installation by assembling the position light to the tip.
