Brief Description: Riveted wing twist jigs together
I assembled and riveted the wing twist jigs together. Pretty fast assembly.
I'm debating on how to setup the jigs in my shop. I really don't need a long, expensive, time consuming, wooden bench to set these on since only the ends of the wings are supported by the fixtures. I think I'll set them up on the floor, check for level and see if I can work at that height. If not, I'll probably buy or build some small tables to raise them off the floor on either end with nothing under the span. I definetly want to assemble both wings at the same time though, so I'll need to make more space.
