DOUGs Web Site
Date:  7-17-2018
Number of Hours:  3.00
Brief Description:  Assembled rear spars with clecos
I unpackaged the the rear spars and trailing edge kit, labeled all parts with a sharpie, used scotch bright to sand mating surfaces, cleaned with alcohol and then primed all of the parts. I then clecod the two assemblies, but did not rivet many parts.
The TAF drawings are usually OK, but not great on instruction. But this step in particular is plagued with CAD drafting errors and took quite a while to figure out what and when to do something. I'm going to wait untill I assemble these and the main spars to the twist jigs before popping in anymore rivets.
unpacked rear spar kits
prep'd and primed all mating parts
clecod rear spar assemblies
