DOUGs Web Site
Sling 2
1 - Connector bracket design & fabrication
I designed a connector bracket in solidworks to mount the strobe, elevator trim and vor antenna conenctors under the vertical stabilizer. I used a drill, file and shears to fabricate it from .024" thick aluminum.
bracket design
holes drilled and filed
part cut out with snips
Sling 2 Home
705
109
Central Fuselage
86
138
Elevator
Horiz Stabilizer
Rear Fuselage
63
101
Shop & Tools
Undercarriage
Vertical Stabilizer
172
