DOUGs Web Site
Date:  5-16-2018
Number of Hours:  1.00
Brief Description:  3 - Rivet removal and bracket install
I used two wraps through the vacant holes from the top so that I could easily identify which rivets to drill out from the bottom. I drilled out the rivets, installed the lower control brackets, and then riveted them in place.
While underneath I noticed the main gear composite was signed by someone; presumable the guy who layed it up.
tie-wraps through holes show location underneath
lower control brackets installed
Someone is proud of their Main Gear
